Do the following to assign a loopback interface to a nondefault VRF.
Because a loopback interface is always available as long as the device is available, it allows routing protocol sessions to stay up even if the outbound interface is down. Assigning a loopback interface to a VRF is similar to assigning any interface. A loopback interface that is not assigned to a nondefault VRF belongs to the default VRF.
		  Enter global configuration mode.
			 device# configure terminal
		  Enter the
			 interface loopback command to specify a loopback interface and enter interface loopback configuration mode.
device(config)# interface loopback 1
device(config-Loopback-1)#
		  Use the
			 vrf forwarding command to assign the interface to the VRF "customer-1" in this example.
			 device(config-Loopback-1)# vrf forwarding customer-1
		  Assign an IPv4 address and mask to the loopback interface.
			 device(config-Loopback-1)# ip address 10.0.0.1/32
