Various show ip bgp neighbor commands verify information about BGP4 neighbor configurations.
device# show ip bgp neighbors
   Total number of BGP Neighbors: 2
1   IP Address: 123.123.123.3, AS: 333 (EBGP), RouterID: 9.9.9.9, VRF: default-vrf
    State: ESTABLISHED, Time: 0h1m32s, KeepAliveTime: 60, HoldTime: 180
       KeepAliveTimer Expire in 17 seconds, HoldTimer Expire in 147 seconds
    Minimal Route Advertisement Interval: 0 seconds
       RefreshCapability: Received
    Messages:    Open    Update  KeepAlive Notification Refresh-Req
       Sent    : 2       15      3339      1            0
       Received: 2       0       3356      0            0
    Last Update Time: NLRI              Withdraw                NLRI                Withdraw
                  Tx: 0h1m32s           ---                 Rx: ---                 ---
    Last Connection Reset Reason:User Reset Peer Session
    Notification Sent:     Cease/Administrative Reset
    Notification Received: Unspecified
    Neighbor NLRI Negotiation:
      Peer configured for IPV4 unicast  Routes
    Neighbor ipv6 MPLS Label Capability Negotiation:
    Neighbor AS4 Capability Negotiation:
    Outbound Policy Group:
       ID: 2, Use Count: 2
    BFD:Disabled
       Byte Sent:   146, Received: 0
       Local host:  123.123.123.2, Local  Port: 44575
       Remote host: 123.123.123.3, Remote Port: 179
2   IP Address: 160.160.160.10, AS: 111 (EBGP), RouterID: 193.24.0.1, VRF: default-vrf
    State: ESTABLISHED, Time: 0h1m33s, KeepAliveTime: 30, HoldTime: 90
       KeepAliveTimer Expire in 12 seconds, HoldTimer Expire in 86 seconds
       Sent    : 8       0       553       5            0
       Received: 8       9       498       0            0
                  Tx: ---               ---                 Rx: 0h1m33s             ---
       ID: 2, Use Count: 2
    BFD:Disabled
       Byte Sent:   121, Received: 0
       Local host:  160.160.160.20, Local  Port: 53791
       Remote host: 160.160.160.10, Remote Port: 179
		  device# show ip bgp neighbors 123.123.123.3 advertised-routes
       There are 5 routes advertised to neighbor 123.123.123.3
Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST E:EBGP I:IBGP L:LOCAL
       Prefix             Next Hop        MED        LocPrf     Weight Status
1      110.110.110.0/24   123.123.123.2    0                    0      BE
         AS_PATH: 222 111
2      110.110.111.0/24   123.123.123.2    0                    0      BE
         AS_PATH: 222 111
3      110.110.112.0/24   123.123.123.2    0                    0      BE
         AS_PATH: 222 111
4      110.110.113.0/24   123.123.123.2    0                    0      BE
         AS_PATH: 222 111
5      110.110.114.0/24   123.123.123.2    0                    0      BE
         AS_PATH: 222 111
		  device# show ip bgp neighbors 123.123.123.3 last-packet-with-error Received Message Length: 45 BGP Message: 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0x002d0104 0x014b00b4 0x09090909 0x10020601 0x04010000 0x01020202 0x00020280 0x00 BGP Header Marker: 0xffffffff 0xffffffff 0xffffffff 0xffffffff Message Length: (0x002d) 45 Message Type: (0x01) OPEN OPEN Message Version: (0x04) 4 AS Number: (0x014b) 331 Hold Time: (0x00b4) 180 BGP Identifier: (0x09090909) 9.9.9.9 Optional Parameter length: (0x10) 16 OPEN message optional parameters Parameter Type: (0x02) Capability Parameter Length: (0x06) 6 Capability Type: (0x01) MULTIPROTOCOL EXTENSIONS Capability Length: (0x04) 4 AFI: (0x0100) Unknown(256) Reserved: (0x00) 0 SAFI: (0x01) Unicast Parameter Type: (0x02) Capability Parameter Length: (0x02) 2 Capability Type: (0x02) ROUTE REFRESH(new) Capability Length: (0x00) 0 Parameter Type: (0x02) Capability Parameter Length: (0x02) 2 Capability Type: (0x80) ROUTE REFRESH(old) Capability Length: (0x00) 0
device# show ip bgp neighbors 160.160.160.10 received-routes
       There are 5 received routes from neighbor 160.160.160.10
Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST C:CONFED_EBGP D:DAMPED
       E:EBGP H:HISTORY I:IBGP L:LOCAL M:MULTIPATH m:NOT-INSTALLED-MULTIPATH
       S:SUPPRESSED F:FILTERED s:STALE
1      110.110.110.0/24   160.160.160.10   0         100        0      BE
         AS_PATH: 111
2      110.110.111.0/24   160.160.160.10   0         100        0      BE
         AS_PATH: 111
3      110.110.112.0/24   160.160.160.10   0         100        0      BE
         AS_PATH: 111
4      110.110.113.0/24   160.160.160.10   0         100        0      BE
         AS_PATH: 111
5      110.110.114.0/24   160.160.160.10   0         100        0      BE
         AS_PATH: 111
		  device# show ip bgp neighbors 123.123.123.3 rib-out-routes
       There are 5 RIB_out routes for neighbor 123.123.123.3
         AS_PATH: 111
         AS_PATH: 111
         AS_PATH: 111
         AS_PATH: 111
         AS_PATH: 111
