VRRP-Ev3 traffic can be load-balanced using short-path forwarding on the backup devices.
		Before configuring VRRP-Ev3 load-balancing, VRRP-Ev3 must be configured on all devices in the VRRP-Ev3 session.
Perform this task on all backup VRRP-Ev3 Layer 3 devices to allow load sharing within an IPv6 VRRP extended group.
		  Use the
			 configure terminal command to enter global configuration mode.
device# configure terminal
		  Globally enable VRRP-Ev3.
device(config)# ipv6 protocol vrrp-extended
		  Enter the
			 interface ve
			  command with an associated VLAN number.
device(config)# interface ve 2019
 In this example, virtual Ethernet (ve) configuration mode is entered and the interface is assigned with a VLAN number of 2019.
		  Enter an IPv6 address for the interface using the
			 ipv6 address
			  command.
device(config-ve-2019)# ipv6 address 2001:2019:8192::122/64
		  Enter the
			 ipv6 vrrp-extended-group
			  command with a number to assign a VRRP-E group to the device.
device(config-ve-2018)# ipv6 vrrp-extended-group 19
 In this example, VRRP-Ev3 group configuration mode is entered.
		  Enter the
			 short-path-forwarding command with a
			 revert-priority value to configure the backup VRRP-E as an alternate path with a specified priority.
device(config-vrrp-extended-group-19)# short-path-forwarding revert-priority 50
 When the backup device priority is higher than the configured
			 revert-priority value, the backup router is able to perform short-path forwarding. If the backup priority is lower than the revert priority, short-path forwarding is disabled.
		In the following example, short-path forwarding is configured on a backup VRRP-Ev3 device and a revert priority threshold is configured. If the backup device priority falls below this threshold, short-path forwarding is disabled.
device# configure
device(config-ve-2019)# ipv6 vrrp-extended-group 19
