Do the following to enable Layer 3 routing on a VLAN.
		  Enter global configuration mode.
			 device# configure terminal
		  Create a VLAN.
		  Create a virtual Ethernet (VE), assign an IP address and mask, and enable the interface.
			 device(config)# interface ve 200
device(config-Ve-200)# ip address 10.2.2.1/24
device(config-Ve-200)# no shutdown
		  A VE interface can exist without a VLAN configuration, but it must be provisioned in the VLAN in order to be used.
		  Enter the
			 router-interface command and specify the VLAN.
device(config-vlan-200)# router-interface ve 200
