Enabling and configuring R-PVST+ on a system
Follow the steps to configure R-PVST+ on a system.
The ports and parameters can be configured individually by:
  1. Entering the commands in steps 1 and 2
  2. Running the relevant addition steps and parameter commands
  3. Verifying the result
  4. Saving the configuration
For detailed descriptions of the parameters and features, see the sections STP parameters and STP features.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enable R-PVST+.
    device(config)# protocol spanning-tree rpvst
    You can shut down R-PVST+ by entering the shutdown command when in rpvst configuration mode.
  3. Configure the bridge priority for the common instance.
    device(config-rpvst)# bridge-priority 4096
    Valid values range from 0 through 61440 in increments of 4096. Assigning a lower priority value indicates that the bridge might become root.
  4. Configure the forward delay parameter.
    device(config-rpvst)# forward-delay  20
  5. Configure the hello time parameter.
    device(config-rpvst)# hello-time 8
  6. Configure the maximum age parameter.
    device(config-rpvst)# max-age 22
  7. Specify the transmit hold count.
    device(config-rpvst)# transmit-holdcount 5
    This command configures the maximum number of BPDUs transmitted per second. The range of values is 1 through 10.
  8. Configure VLANs.
    1. Configure VLAN 100 with a priority of 0.
      device(config-rpvst)# vlan 100 priority 0
      Valid priority values range from 0 through 61440 in multiples of 4096.
    2. Configure VLAN 201 with a priority of 12288.
      device(config-rpvst)# vlan 201 priority 12288
    3. Configure VLAN 301 with a priority of 20480.
      device(config-rpvst)# vlan 301 priority 20480
  9. Set the switching characteristics for interface 0/3.
    1. Enter interface configuration mode.
      device(config-rpvst)# interface ethernet 0/3
    2. Set the switching characteristics of the interface.
      device(conf-if-eth-0/3)# switchport
    3. Set the interface mode to trunk.
      device(conf-if-eth-0/3)# switchport mode trunk
    4. Add VLAN 100 as a member VLAN.
      device(conf-if-eth-0/3)# switchport trunk allowed vlan add 100
    5. Add VLAN 201 as a member VLAN.
      device(conf-if-eth-0/3)# switchport trunk allowed vlan add 201
    6. Add VLAN 301 as a member VLAN.
      device(conf-if-eth-0/3)# switchport trunk allowed vlan add 301
    7. Enable spanning tree on the interface.
      device(conf-if-eth-0/3)# no spanning-tree shutdown
    8. Return to privileged EXEC mode.
      device(conf-if-eth-0/3)# exit
  10. Set the switching characteristics for interface 0/4.
      device(config-rpvst)# interface ethernet 0/4
      device(conf-if-eth-0/4)# switchport
      device(conf-if-eth-0/4)# switchport mode trunk
      device(conf-if-eth-0/4)# switchport trunk allowed vlan add 100
      device(conf-if-eth-0/4)# switchport trunk allowed vlan add 201
      device(conf-if-eth-0/4)# switchport trunk allowed vlan add 301
      device(conf-if-eth-0/4)# no spanning-tree shutdown
      device(conf-if-eth-0/4)# exit
  11. To interoperate with switches other than VDX switches in R-PVST+ mode, you must configure the interface that is connected to that switch.
    1. Enter interface configuration mode for the port that interoperates with a VDX switch.
      device(config)# interface ethernet 0/12
    2. Specify the MAC address for the device.
      device(conf-if-eth-0/12)# spanning-tree bpdu-mac 0100.0ccc.cccd
    3. Enable spanning tree on the interface.
      device(conf-if-eth-0/12)# no spanning-tree shutdown
    4. Return to privileged EXEC mode.
      device(conf-if-eth-0/12)# end
  12. Verify the configuration.
    device# show spanning-tree
    VLAN 1
     Spanning-tree Mode: Rapid PVST Protocol
     Root Id: 0001.01e0.5200.0180 (self)
     Bridge Id: 0001.01e0.5200.0180
     Root Bridge Forward Delay: 15; Hello Time: 2; Max Age: 20; Max-hops: 20
     Configured Forward Delay: 20; Hello Time: 8; Max Age: 22; Max-hops: 20
     Tx-HoldCount 5
     Number of topology change(s): 0
     Bpdu-guard errdisable timeout: disabled
     Bpdu-guard errdisable timeout interval: 300 sec
     Port Et 0/3 enabled
        Ifindex: 201351168; Id: 8001; Role: Disabled; State: Disabled
        Designated Path Cost: 0
        Configured Path Cost: 20000000
        Designated Port Id: 0; Port Priority: 128
        Designated Bridge: 0000.0000.0000.0000
        Number of forward-transitions: 0
        Version: Per-VLAN Spanning Tree Protocol - Received None - Sent STP
        Portfast: off
        Configured Root guard: off; Operational Root guard: off
        Bpdu-guard: off
        Link-type: point-to-point
        Received BPDUs: 0; Sent BPDUs: 0
     Port Et 0/4 enabled
        Ifindex: 201359360; Id: 8002; Role: Disabled; State: Disabled
        Portfast: off
        Bpdu-guard: off
    VLAN 100
     Root Id: 0064.01e0.5200.0180 (self)
     Bridge Id: 0064.01e0.5200.0180
     Tx-HoldCount 5
     Port Et 0/3 enabled
        Portfast: off
        Bpdu-guard: off
     Port Et 0/4 enabled
        Portfast: off
        Bpdu-guard: off
    VLAN 201
     Root Id: 30c9.01e0.5200.0180 (self)
     Bridge Id: 30c9.01e0.5200.0180
     Tx-HoldCount 5
     Port Et 0/3 enabled
        Portfast: off
        Bpdu-guard: off
     Port Et 0/4 enabled
        Portfast: off
        Bpdu-guard: off
    VLAN 301
     Root Id: 512d.01e0.5200.0180 (self)
     Bridge Id: 512d.01e0.5200.0180
     Tx-HoldCount 5
     Port Et 0/3 enabled
        Portfast: off
        Bpdu-guard: off
     Port Et 0/4 enabled
        Portfast: off
        Bpdu-guard: off
    Observe that the settings comply with the formula set out in the STP parameters section, as:
    (2 × (forward delay - 1)) ≥ maximum age ≥ (2 × (hello time + 1))
    or in this case: 28 ≥ 20 ≥ 6.
  13. Save the configuration.
Enable R-PVST+ on a system configuration example
device(config)# interface ethernet 0/4
device(conf-if-eth-0/4)# end
