External-collector streaming
For each target collector device, you configure a local
telemetry collector object
that specifies the following parameters:
- One or more telemetry
profiles
- IPv4 address/port of the
collector device
- Encoding format (Google protocol
buffers (GPB) or JavaScript object notation (JSON))
- (Optional) VRF
- Activation
The following diagram depicts the many-to-many relationships between profiles and
collectors:
- You can specify multiple profiles
in a collector.
- You can specify a profile in
multiple collectors.
The preceding diagram does not depict local
telemetry
collector objects.
