Deleting a syslog CA certificate
The following procedure deletes the syslog CA certificates of all attached Active Directory servers from the device.
  1. Connect to the device and log in using an account with admin role permissions.
  2. In privileged EXEC mode, enter the no crypto import syslogca command. You will be prompted to confirm that you want to delete the syslog CA certificates.
This example deletes the syslog CA certificates.
SLX# no crypto import syslogca
Do you want to delete syslogca certificate? [y/n]:y
Warning: All the syslog CA certificates are deleted.
