| 10953 | 10951 | 10941 | XN-ACPWR-2000-F* | |
| Voltage Input Range (Nominal) | 100VAC-127VAC/ 200VAC-240VAC | 100VAC-127VAC/ 200VAC-240VAC | 100VAC-127VAC/ 200VAC-240VAC | 100VAC-127VAC/ 200VAC-240VAC |
| Line Frequency Range | 50Hz to 60Hz | 50Hz to 60Hz | 50Hz to 60Hz | 50Hz to 60Hz |
| Power Supply Input Socket | IEC/EN 60320 C14 | IEC/EN 60320 C16 | IEC/EN 60320 C16 | IEC/EN 60320 C16 |
| Power Cord Input Plug | IEC/EN 60320 C13 | IEC/EN 60320 C15 | IEC/EN 60320 C15 | IEC/EN 60320 C15 |
| Operating Temperature | 0°C to 55°C (32°F to 131°F) Normal Operation | 0°C to 50°C (32°F to 122°F) Normal Operation | 0°C to 50°C (32°F to 122°F) Normal Operation | 0°C to 55°C (32°F to 131°F) Normal Operation |
| XN-ACPWR-350W-FB | XN-ACPWR-350W-BF | XN-ACPWR-715W-FB | XN-ACPWR-1100W-FB | XN-ACPWR-2000W-FB* | |
| Voltage Input Range (Nominal) | 100VAC-240VAC | 100VAC-240VAC | 100VAC-240VAC | 100VAC-240VAC | 100VAC-240VAC |
| Line Frequency Range | 50Hz to 60Hz | 50Hz to 60Hz | 50Hz to 60Hz | 50Hz to 60Hz | 50Hz to 60Hz |
| Power Supply Input Socket | IEC/EN 60320 C14 | IEC/EN 60320 C14 | IEC/EN 60320 C16 | IEC/EN 60320 C16 | IEC/EN 60320 C16 |
| Power Cord Input Plug | IEC/EN 60320 C13 | IEC/EN 60320 C13 | IEC/EN 60320 C15 | IEC/EN 60320 C15 | IEC/EN 60320 C15 |
| Operating Temperature | 0°C to 55°C (32°F to 131°F) Normal Operation | 0°C to 55°C (32°F to 131°F) Normal Operation | 0°C to 50°C (32°F to 122°F) Normal Operation | 0°C to 50°C (32°F to 122°F) Normal Operation | 0°C to 50°C (32°F to 122°F) Normal Operation |
| XN-ACPWR-550W-FB | XN-ACPWR-550W-BF | XN-DCPWR-550W-FB | XN-DCPWR-550W-BF | |
| Voltage Input Range (Nominal) | 100VAC-240VAC | 100VAC-240VAC | -48VDC (-36VDC to -72VDC) | -48VDC (-36VDC to -72VDC) |
| Line Frequency Range | 50Hz to 60Hz | 50Hz to 60Hz | N/A | N/A |
| Power Supply Input Socket | IEC 320 - C14 | IEC 320 - C14 | POSITRONIC PN# PLAH03M400A1/AA-E1A | POSITRONIC PN# PLAH03M400A1/AA-E1A |
| Power Cord Input Plug | IEC 320 - C13 | IEC 320 - C13 | POSITRONIC PN# PLAH03M400A1/AA-E1A | POSITRONIC PN# PLAH03M400A1/AA-E1A |
| Operating Temperature | 0°C to 50°C (32°F to 122°F) Normal Operation | 0°C to 50°C (32°F to 122°F) Normal Operation | 0°C to 50°C (32°F to 122°F) Normal Operation | 0°C to 50°C (32°F to 122°F) Normal Operation |
| Switch Model | 1 x 715W | 2x 715W | 1 x 1100W | 2 x 1100W |
1 x 2000W @ 100-120VAC |
1 x 2000W @ 200-240VAC |
2 x 2000W @ 100-120VAC |
2 x 2000W @ 200-240VAC |
| 5520-24W | 494W | 1079W | 879W | 1781W | 879W | 1779W | 1869W | 2160W |
| 5520-48W | 483W | 1068W | 868W | 1770W | 868W | 1768W | 1858W | 3568W |
| 5520-12MW-36W | 464W | 1049W | 849W | 1751W | 849W | 1749W | 1839W | 3549W |
Note: It is recommended that primary and secondary power supply units (PSUs) be of the same type to support optimal PoE operation.
| Switch Model | Minimum Power Consumption (W) | Minimum Heat Dissipation (BTU/hr) | Maximum Power Consumption (W)* | Maximum Heat Dissipation (BTU/hr)** |
| 5520-24T | 52 | 176 | 142 | 483 |
| 5520-24W | 54 | 182 | 2480 | 1092 |
| 5520-48T | 60 | 205 | 171 | 584 |
| 5520-48W | 59 | 203 | 4100 | 1817 |
| 5520-12MW-36W | 66 | 224 | 4095 | 1862 |
| 5520-48SE | 61 | 209 | 255 | 872 |
| 5520-24X | 48 | 165 | 171 | 585 |
| 5520-24T-ACDC | 41 | 140 | 135 | 459 |
| 5520-48T-ACDC | 46 | 156 | 141 | 481 |
| 5520-24X-ACDC | 39 | 132 | 169 | 575 |
| 5520-48SE-ACDC | 45 | 154 | 223 | 760 |
