Replace Virtual Port Extenders
5520 Series switches support the following virtual port extenders:
Remove a Virtual Port Extender
Use the following instructions to remove a virtual port extender.
  1. Disconnect the port extender from its power source and, if applicable, from its redundant power supply.
  2. Support the port extender while you remove the rack-mounting screws that hold the front mounting brackets in place against the rack posts.
  3. Carefully slide the port extender out of the rack.
  4. Place the port extender on a secure, flat surface. Optionally, remove the mounting brackets from the sides.
  5. Optionally, install a new virtual port extender.
Remove a Half-Duplex to Full-Duplex Converter
Use the following instructions to remove a Half-Duplex to Full-Duplex converter
  1. Disconnect the half-duplex ports (HD1 - HD4) from your half-duplex devices.
  2. Disconnect the full-duplex ports (FD1 - FD4) from the switch.
  3. Disconnect the converter from its power adapter.
    1. Disconnect the power adapter from its AC power source.
    2. Disconnect the DC power cable from the power adapter and from the DC input socket on the side of the converter.
    3. Remove the grounding wire from the converter.
  4. If the converter is attached to a 3-slot modular shelf, loosen the cable ties and remove it from the shelf.
  5. Optionally, install a new converter.
