There are two supported modes for ExtremeSwitching 5520-VIM port LEDs:
In the default SYS mode, SPD is OFF, and the port status displays behavior for link, traffic, and PoE as described in the following table:
Color/State |
Meaning |
Solid green |
Link is OK; port is not powered |
Blinking green |
Link is OK and transmitting packets; port is not powered |
Slow blinking green |
Port is admin disabled |
Off |
Port is not powered, has no link |
SPD mode is used to help determine the operational speed of a port. Color and blink pattern indicate speeds, as referenced by the following table:
Color/State |
Speed |
10Gbps |
Solid green |
1Gbps |
Fast blinking green |
25Gbps |
