Use the License
page to link the venue account to the Extreme Licensing Portal and to assign license
capacity for a venue.
- Administrators with the License permission can
access venue licensing information based on the user type of the
administrator. For example, an administrator at the Customer level can view
and update licensing for all venues under that customer whereas an
administrator at the Venue level can view and
update licensing for a specific venue only.
- Only
administrators who have the License permission can
view and use the License page.
- To
assign license capacity, you must have purchased licenses already.
- To link
the venue account to the Extreme Licensing Portal, you need a user account
with sign in access to the portal.
Contact your Extreme Networks representative if you need
help with any of these requirements.
From the navigation menu, select License.
If the listed venues are not
linked to an Extreme Portal account, do the following to link the account to the
portal:
Select Link to Extreme
Portal.
Sign in to the Extreme
Licensing Portal using credentials for a user account that has access to
the portal.
After the linkage
is complete, the linked licensing account information displays at the
top of the page.
In the Business Insights
interface, assign license capacity for each venue:
In the LICENSE
field, set the venue license capacity to a value that is greater than or
equal to the number of clients that you expect to use the Wi-Fi network
over a 24-hour period.
Select the adjacent
Update button to save the license capacity.
Repeat these steps until
you have assigned license capacity for each venue.
