Apply edits to an existing custom dashboard, for example you can add or remove
charts from the dashboard.
From the navigation menu, select Dashboards > Custom.
For the dashboard that you want to edit, select the icon in the top right of the dashboard label and then select Edit Dashboard.
The dashboard opens in edit mode. The
chart library displays on the left, showing charts that are available for you to
add to the custom dashboard.
Make any edits that you want to
the dashboard:
To add a chart, select
and drag the chart onto the dashboard.
To
remove a chart or card, select the (Remove) icon in the top right of the chart or card and select
Delete.
Select Save.
You can also
delete a custom dashboard from the Custom Dashboards page. For
the dashboard that you want to delete, select the icon in the top right of the dashboard
label, select Delete Dashboard, and then select
Delete.
