Navigation Menu
Once you're logged in to the application, you can select from the options in the navigation menu to navigate to specific content pages.
To open the navigation menu, select the Business Insights navigation icon . From the menu, select the page that you want to view. The following pages are available:
Dashboards
Select this navigation item to display the following submenu items:
  • Historical—Dashboards that display historical data for a completed event.
  • Live—Dashboards that display data for an event that is currently taking place. For live events, the data is updated in real time.
  • Comparative—Dashboards that compare data for multiple events. Includes the Suites Engagement Dashboard.
  • Custom—Dashboards that you create and customize to display the data that you want to see.
Schedule
View a calendar that shows scheduled and custom events by month. You can also create custom events directly the calendar or launch historical dashboards for completed events.
Custom Events
View data for custom events that are outside the normal schedule. You can also add or delete custom events from the schedule.
Custom Markers
Upload a csv file or Excel spreadsheet with custom markers that you can apply to an event in order to mark important moments.
Location Mappings
Select this navigation item to display the following submenu item:
  • Mappings—Create labels to map your access points to venue locations.
  • Upload CSV file—Import a CSV file that has your access point mapping.
Pre Flight Checks
Run pre flight checks at a venue in order to test network readiness and to look for potential issues.
User Management
If you have the required Administrator permissions, use this menu to manage users on the system. You can add, update, or delete users. In addition, you can change passwords for users.
Tracked Applications
Select the applications for which data will be collected.
Data Studio
Create and edit your own custom charts that can be added to custom dashboards.
Some of the navigation items are available only if you have Administrator permissions. For details, see "Permissions" under User Access.
