Edit an Existing Custom Chart
Use Data Studio to edit an existing custom chart.
  1. From the navigation menu, select Data Studio
  2. Select Edit Charts.
  3. For the chart that you want to edit, select the Chart Actions icon within the chart label and then select Edit Chart.
    If there are no charts with the data you want, search for the chart by entering the chart name in the Search box.
  4. Under Chart Details, edit any of the drop-down options that you want to change.
  5. If you want to edit the query, select Open Query Builder and do the following:
    1. Edit any rules and rulesets to which you want to apply changes. You can edit, add or remove rules and rulesets.
    2. Select Apply.
  6. Preview how the chart looks:
    1. Select an event by choosing appropriate values from the drop-down windows across the top of the right window.
    2. Select Preview Chart.
  7. Select Save.
You can also use the Edit Charts options within Data Studio to delete an existing custom chart. In step 3 above, select the Chart Actions icon for the applicable chart and select Delete Chart.
