The following table describes the fields that display on the License page.
| Field | Description | ||||||
| Link to Extreme Portal | Select this button to link the venues under a customer account to
the applicable Extreme Portal account. Business Insights checks the
portal for licensing capacity that this customer has purchased and
populates the License page with the license totals that are
available for allocation to venues. Note: This button
displays only if the account is NOT linked to the Extreme
Portal.
| Linked Customer Fields—The fields in this section appear only for linked customer accounts. | |||||||
| Name | The name of the customer. | ||||||
| Shared CUID | The unique customer identifier. | ||||||
| Total licenses | The total number of licenses that the customer has purchased. | ||||||
Remaining licenses |
The total number of licenses for this customer that are not assigned to venues. This value can be derived with the following formula: Remaining licenses = Total licenses - Total assigned licenses Note: Any new license
capacity that you assign gets subtracted from the value in this
field. For example, if you have 50,000 remaining licenses and
you assign 30,000 licenses to venues, you have 20,000 remaining
licenses.
| Unlink from Extreme Portal | Select this button to unlink the venues under a customer account from the applicable Extreme Portal account. Selecting this option removes the license allocation for all displayed venues. To reassign the license capacity to these venues, you must re-link the account to the Extreme Networks portal. | ||||||
| Licensing Fields | |||||||
| VENUE | The name of the venue. | ||||||
LICENSES |
The client license capacity that is allocated to this venue for use during a 24-hour period. You can edit this value to assign or remove license capacity for the venue. Update—After you edit the capacity, select the adjacent Update button to save the setting and to update the license fields on this page. Note: Assign a value
that is greater than, or equal to, the total number of clients
that you expect to use the Wi-Fi network
during event days. For example, the value in this field should
always be greater than or equal to the value of the CLIENT COUNT
(PAST 24 HOURS) field.
Note: Any new license capacity that you assign gets subtracted from
the value of the Remaining
licenses field.
| CLIENT COUNT (PAST 24 HOURS) | The number of clients, based on unique MAC addresses, or IP
addresses if MACs are not available, that accessed the venue's Wi-Fi
network during the previous 24-hour period. This field gets updated
once per day with the totals for the previous day. Note: To maintain a
Green status, make sure that this value does not exceed the
venue license capacity (as per the LICENSES field).
| STATUS | The status of license allocation and usage
at the venue. Each venue receives one of the following three
color-coded statuses:
Note: A red icon
| MESSAGE | Provides additional information on the STATUS field. If the status is Yellow or Red, the message provides the reason for the status and details on how you can resolve the issue. | ||||||
