Pre flight checks let you test a venue's network readiness prior to a live event. Pre flight checks are run on the day of the event. They may be run after the venue has started tracking live data for the event, but prior to the scheduled start time of the event. However, you can also run pre flight checks during the scheduled event.
To run a check:
(Configuration) icon for the venue and do the following:
We recommend that you don't run AP checks during a scheduled event as some checks may take the AP offline.The results display in the window. Refer to the following sections for more information on the checks that are run and the results that are returned.
Pre flight checks includes the following types of checks:
The list of checks may vary from the documented list depending on which products you've integrated with Business Insights.
| Check Type | Description |
XIQ-C Ingestion |
This check tests whether ExtremeCloud IQ Controller (XIQ-C) is sending data as expected by checking when the “MU Table” and “AP Table” of a venue were last updated. The check returns the following results:
Traffic Sensor ingestion |
This check tests whether raw data is being ingested through the traffic sensor and that this raw data is being processed into entries in the application table. The check returns the following results:
Upcoming Events |
This check tests whether there are upcoming or ongoing events scheduled for a venue. The check returns the current event (if one exists) and the next scheduled event. The check categorizes events as "upcoming" or "ongoing" using the following logic:
Diagnostic Check: Event Selectors Endpoint |
This check tests whether the selectors that are used to find the current live event for a venue are being generated as expected. The check first determines if there is a live event currently running at the venue. If there is not a live event, the check is not run. The check looks through all the selectors for live events, matches them with the live events in the venue schedule, and confirms that each live event in the schedule has a corresponding selector.
Diagnostic Check: Event Timezone Endpoint |
This check tests whether the time zone for the current live event at the venue matches the time zone for the venue that was set in the configuration.
Diagnostic Check: Charts Run Endpoint |
This check tests whether the venue can receive data and is able to transform the data into charts. The check first determines if the venue has the right configurations to receive both ExtremeCloud IQ Controller data and traffic sensor data. The check then tests whether there is currently a live event at the venue and attempts to create a chart from the received data.
AP Check: Basic Wired Connectivity |
This check tests whether selected network access point devices can connect to the local internet‘s wired connection. The check connects to ExtremeCloud IQ Controller at the venue, which signals to the selected APs to emulate being a wired client and to ping the default gateway to verify internet access. The check takes the average roundtrip times for each AP‘s ping test.
Check Results following table provides a description of the results for a pre flight check.
| Field | Description |
| Check Type | Lists the checks that Business Insights completes on this venue. |
| Status | Status of the check. Valid values are:
| Start | Start time for the check. |
| End | End time for the check. |
| Message | A message that provides details about the check results. |
