ExtremeCloud Edge v5.11.01 Managed Orchestration Deployment Guide
Appendix
> Appendix C: Replace or Add a Node
Extreme Networks, Inc. June 25, 2025
Abstract
Preface
Introduction
Managed Orchestration Cluster
Kubernetes
Deployment Responsibilities
Requirements
ExtremeCloud Edge Planning
Firewall Access for Critical Settings
Prerequisites for ExtremeCloud Edge Installation
IP Addresses
VRRP Configuration
Reserved IP Addressing
Port Information for Firewalls
Source Address Information
Supported Hardware for Managed Orchestration
Configure the Deployment
Basic Configuration Wizard
Use the Basic Configuration Wizard
Upgrade the Appliance Software
IP Address Configuration
Configure VRRP (VIP)
Configure the Cluster Settings
Run Readiness Assessment
Install ExtremeCloud IQ Engine
Validate the Cluster
Onboard Cluster to ExtremeCloud IQ
Onboarding a Cluster to ExtremeCloud IQ
Account Registration
Cloud Visibility
Appendix
Appendix A: ExtremeCloud IQ - Site Engine Integration with ExtremeCloud Edge
Appendix B: Migrate Virtual IQ Account
Export VIQ Account
Import VIQ Account
Prepare to Replace a Node
Replace a Node
Add Node
Use the procedures in this Appendix if you need to replace a node or add a node.
