Use this procedure to import the VIQ export file into the new RDC. Note the following:
- If a conflict occurs, imported objects get renamed.
- Source and destination VHMs must be the same version. Otherwise, an incompatible data scheme occurs.
- From ExtremeCloud IQ Pilot, go to .
- Create a backup of the current VHM:
- Under VIQ Management, select BACK UP NOW.
- Select YES.
VIQ suspends itself until the backup completes.
- Import the VHM export file that you created in the preceding procedure:
- Select Import VIQ.
- Select Import VIQ from ExtremeCloud IQ.
- Select Choose and then browse and select the VHM export file.
- Select Import Now.
- After the import completes, select OK.
- If the import fails, download the log file for information on the issues.
- If you need to roll back the import, restore the backup.
