Configure the Cluster Settings
An engine is an instance of a containerized application. This process follows the user interface to configure the orchestration engine settings. From the management IP address, log into the user interface using the admin credentials that you configured under Use the Basic Configuration Wizard.
Go to Cluster Settings > Cluster Configuration and configure the cluster following the order shown on screen:
  1. Deployment Type
  2. Cluster Node Information
  3. Pod Network Configuration
  4. Finish
Complete these steps to configure the cluster
  1. From the Deployment Type drop-down list, select ExtremeCloud Edge - Managed Orchestration.
  2. In the Cluster Node Information section, select Cluster mode. Enter the ICC IP addresses and click Next.
    Appliance Configuration
    ICC IP (Management) Address for Appliance
  3. Provide the settings for Pod Network Configuration:
    • Pod Network IP Address
    • Pod Network CIDR
    • Service Network IP Address
    • Service Network CIDR
    Pod Settings
    Pod Configuration Settings
  4. Select Create Cluster.
    Cluster Creation Process
  5. Select Done.
    Dashboard Displays Results
