ExtremeCloud™ IQ is the only available engine for an ExtremeCloud Edge - Managed Orchestration deployment. Install the ExtremeCloud IQ engine once from a single node.
Installing the ExtremeCloud IQ engine prepares the cluster to receive the ExtremeCloud IQ application but does not install the application. Extreme CloudOps completes the application installation after you onboard the cluster and register your account.Note
An Edge Cloud deployment of ExtremeCloud IQ must be configured in a cluster of three or more nodes in multiples of three. The minium number of cluster nodes is three for ExtremeCloud IQ only, and six nodes if you're also deploying other applications. ExtremeCloud IQ is not supported in stand-alone mode, requires a cluster, and does not support engine types other than ExtremeCloud IQ.
