Use the configuration wizard to initialize nodes in a cluster to the pre-determined IP addresses.
IP address configuration for interfaces on the cluster must be set only once. If you change IP addresses after initial deployment (for example, due to a cluster relocation), you must rebuild and re-deploy the cluster, and re-install the application.
The following is example information that must be gathered during the prerequisite stages for each node in the cluster, and for the ICC VRRP:
IP Address
A unique IP address for each node. Example:192.227.109.81
Mask
Common Mask. Example:/26 (255.255.255.192)
Gateway
Common Gateway. Example:192.227.109.65
VRRP Precedence
Common Router ID with a unique precedence level for each node. Provide a unique precedence value for each node.
