ExtremeCloud Edge Planning
This guide outlines the steps required to prepare a cluster environment that will support deployment of ExtremeCloud Edge applications to the customers' premises.
Minimum Requirements for Installation
Application requirements for the cluster configuration:
Out-of-Bound Routing for Outgoing Traffic
The VRRP service set mappings provide load balancing and service abstraction for incoming traffic. For outgoing traffic that originates from installed components, including responding to incoming traffic that came through these mappings, is steered through the default gateway. At the internal firewall, the source address for the outgoing traffic is the address of the data interface on the node from which the traffic originated.
Service Set 1: Cluster Administration, Account Access (https), CAPWAP Master, Diagnostics
Table 1. Example port assignments for Service Set 1
PortProtocolServiceDescription
80TCPCAPWAPCAPWAP Master
443TCPNGINXExtremeCloud IQ Admin, software management
1443TCPXAPIExtremeCloud IQ API
2083 TCPIDMIDM Auth
12222 UDPCAPWAPCAPWAP Master
Service Set 2: AP Registration/CAPWAP Load Balancing
Table 2. Example port assignments for Service Set 2
80 TCPCAPWAPCAPWAP Master
443TCPSD-WANSD-WAN Communicator
5825 TCPInletsDevice Communication
8090TCPInletsDevice Communication
9090TCPSD-WANSD-WAN Communicator
12222UDPCAPWAPCAPWAP Master
Service Set 3: AP Registration/CAPWAP Load Balancing
Table 3. Example port assignments for Service Set 3
443 TCPSD-WANSD-WAN Communicator
Service Set 4: AP Registration/CAPWAP Load Balancing
Table 4. Example port assignments for Service Set 4
443TCPNGINXExtremeCloud GDC access
1443 TCPXAPIExtremeCloud IQ API
1444 TCPAPIGDC API
1445TCPLicenseExtremeCloud IQ License Management
