Use this procedure to create and download an export file for a VIQ account.
- In ExtremeCloud IQ Pilot, go to Global Settings and select VIQ Management.
- Create a backup of the current VHM:
- Under VIQ Management, select BACK UP NOW.
- Select YES.
VIQ suspends itself until the backup completes.
- Export the VHM to a local drive:
- Go to Global Settings and select VIQ Management.
- Select Export VIQ.
- In the VIQ Export popup window, select Export Now.
- Click YES. VIQ suspends itself until the Export completes.
- Once the export completes successfully, select OK.
If the export fails, click the
Detailed Report link to get a detailed report on the issue.
What to do Next
After the export file downloads, you can import the file into a different Regional Data Center (RDC).
