Configure Interface Settings for Engine Application
Use this procedure to configure the final
application interface settings immediately after you deploy an application. You can use
these settings to assign a VRRP IP alias to the application (which is required for some
applications).
Refer to the documentation for your engine application
for application-specific requirements. Configuration requirements can vary
per application.
Go to the application interface settings page for
your application.
The page launches automatically after you
select the Deploy
option for a newly installed application. Otherwise, go to Engines > Installation and then select the link for the engine instance.
Copy or record the Locking ID (Serial Number).
Most applications require you to provide this value during license
activation.
Optional. If your engine application requires you
to configure a VRRP IP alias:
Select the Network Service
Configuration tab.
From the Assigned Virtual IP
Address field, select a VRRP address that you assigned
previously on a data port.
Select Save.
Optional. To launch the application user
interface, select the Instance Web
Interface link.
