Engine Application Settings
After you deploy a newly installed engine, the settings page for the installed application displays with settings for that engine instance. You can also access this page by going to Engines > Installation and then selecting the instance. The name of the application displays at the top of the screen (for example, "Extreme Tunnel Concentrator").
Depending on which application engine you installed, the displayed fields may vary:
Select either of the following commands to reboot or restart an active application:
The following four tabs display across the middle of the page. You can use these tabs for diagnostic information about application services.
Network Service Configuration
For applications that require a VRRP IP alias, this tab displays the Assigned Virtual IP Address field. If the application requires that you assign a VRRP IP alias, from the drop-down , select a VRRP address that was configured previously on one of the data ports. The VRRP alias provides an IP address for access to the application's management interface.
VRRP enables a virtual router to act as the default network gateway, improving host network reliability and performance.
For a given VRRP address to display, the VRRP address must have been added already on one of the data ports for the Universal Compute Platform host.
Statistics
Compute statistics and node drive volume statistics are available for CPU usage and memory usage.
Logs
A log file is available for each node instance. Log entries include the following:
  • Timestamp of log entry
  • System Component
  • Message log level
  • Message content
Console
A live console is available from each engine instance for diagnostics and troubleshooting. To open a live console and connect to a container or virtual machine instance (VMI), from the engine Console tab, select Attach.
