Refer to your engine application documentation for requirements that are specific to the engine.| Step | Procedure | Description |
| 1 | Download the Docker Application Image | Download the application image from the Extreme Networks support portal. |
| 2 | Upload Application Image to Appliance | Upload the application image to the Universal Compute Platform appliance. |
| 3 | Install Engine Application | Install the application image on the appliance. |
| 4 | Deploy Application | Deploy the application engine on the appliance. |
| 5 | Configure Interface Settings for Engine Application | Configure application interface settings specific to the application. For example, you can obtain the Locking ID for licensing or assign a VRRP IP alias. |
| 6 | Engine Upgrades | Upgrade the application software. Select the upgrade method that fits your application type. |
What to do Next
To onboard the application to the cloud, go to Cloud Onboarding.
