The Universal Compute Platform relies on Virtual Router Redundancy Protocol (VRRP) to provide IP abstraction to key functionality.
Some applications request that you configure a VRRP address for access to that application's management interface. VRRP can be used to configure an IP alias with pass-through capability for the Universal Compute Platform data interface to that application's management interface.
VRRP IPs must be within the same segment as configured for the interface.
VRRP IP addresses must not overlap with any other address in use in the segment, including addresses that are assigned by the application.
In a standalone cluster configuration, configure Priority and Router ID with numeric values. However, the specific values are not important. These attribute definitions are import in mant in multiple-node configurations only.For details, see Add a Port.
