Install Kubernetes (Offline Installation)
Use this procedure only if you are doing a fresh installation and configuring the standalone cluster while working offline. In this case, you must upload and install a Kubernetes image before you create the cluster.
For online installations, you can skip this procedure as Kubernetes installs automatically when you create the standalone cluster.
  1. Go to Administration > System > Software Upgrade.
  2. Select the Kubernetes tab.
  3. Upload the image file using one of the following two methods:
    • On the Kubernetes page, select (Upload Kubernetes resource package zip file) and then browse to the image file and select it.
    • On your desktop, select the image file and drag it into the Upload Kubernetes resource package zip file area of the Kubernetes page.
    The image file uploads to Universal Compute Platform and then installs automatically.
    If you want to delete an Available image, select the adjacent (Remove Mirror).
