Supported Appliances for Self-Orchestration
ExtremeCloud Edge - Self-Orchestration deployments of Universal Compute Platform support the following hardware appliances. Depending on the hardware, you may be able to install more than one instance of an application on a node.
Support is for a single application type per node. Application mixing on a single appliance is not supported.
Table 1. Supported Hardware for ExtremeCloud Edge - Self-Orchestration
Hardware ApplianceDetails
1130C
Ports:
  • 2 x 1 Gbps ICC Ports/RJ45
  • 4 x 1 Gbps Data 1-4/RJ45
Self-Orchestration deployment application capacity:
  • Tunnel Concentrator—One instance per node
  • ExtremeCloud IQ Controller (CE1000)—One instance per node.
  • Third-Party Management Engine—One instance per node.
  • PSConsole—One instance per node.
For additional server specifications, along with hardware installation information, see Universal Compute Platform Appliance 1130C Installation Guide.
2130C
Ports:
  • 2 x 1/10 Gbps ICC Ports/RJ45
  • 2 x 1/10 Gbps Data 1-2/RJ45
  • 2 x 10/25 Gbps Data Ports 3-4/SFP28
  • ExtremeCloud IQ Controller (CE2000)—One instance per node.
  • ExtremeCloud IQ - Site Engine—One instance per node.
  • ExtremeControl—One instance per node.
  • ExtremeAnalytics—One instance per node.
For additional server specifications, along with hardware installation information, see Universal Compute Platform Appliance 2130C Installation Guide.
3150C
Ports:
  • 2 x 10/25 Gbps Data Ports 1-2/SFP28
  • 2 x 10/25/50/100 Gbps Data Ports 3-4/QSFP28
  • Tunnel Concentrator—One instance per node.
  • ExtremeCloud IQ Controller (CE3000)—One instance per node.
  • ExtremeControl—Two instances per node.
  • ExtremeWireless WiNG Controller (CX9000)—One instance per node.
For additional server specifications, along with hardware installation information, see Universal Compute Platform Appliance 3150C Installation Guide
4120C/4120C-1
Ports:
  • 2 x 1/10/25/40/50 Gbps Data 3-4/QSFP
  • Tunnel Concentrator—Up to three instances per node.
For additional server specifications, along with hardware install information, see Universal Compute Platform Appliance 4120C Installation Guide.
Appliance Installation and Specifications Documentation
For appliance installation and technical specifications information, see the Universal Compute Platform Appliance Installation Guide for your specific hardware appliance model. These guides contain the following information:
