Deploy Application
After you have installed the engine on the appliance, deploy the application.
  1. Go to Engines > Installation.
  2. Select the engine instance link. For example, "cx9000 #1".
  3. Assign virtual functions (VFs) to the ports. We recommend that you retain the default settings, although you can assign any unassigned VF.
  4. Select Deploy.
