Onboard Cluster to Extreme Platform ONE Networking
Use this procedure to onboard a standalone cluster
to Extreme Platform ONE Networking.
Log in to Extreme Platform ONE Networking.
Go to Monitoring > Network Devices.
Select Add Devices and then select
Manually.
In the Manually Add Devices
window, do the following:
Select Cloud Managed.
For Device Type, select
Universal Compute
Platform.
For Serial No., enter the
serial number of the appliance.
To obtain the serial number of the
appliance, go to Administration > System > System
Information and then select the Manufacturing
Information tab. The serial number is in the
Manufacturing ID (Serial Number)
field.
If you want to onboard more than one
appliance, select (+) to
add more rows where you can enter additional serial numbers.
You can add up to ten appliances.
