AP3000 Series Radios and 6 GHz Support
The AP3000 series access points are Wi-Fi 6E tri-radio access points with support for multiple Extreme Networks operating systems. The AP3000 series access points include the following AP models:
  • AP3000 — Indoor access point
  • AP3000X — Indoor access point with optional external antenna.
The AP3000 series access points offer two radios in three modes:
Table 1. AP3000/X Operating Modes
Mode
Radio 1 (2x2)
Radio 2 (2x2)
Radio Definitions
1 (Default) g/n/ax a/n/ac/ax 2.4 GHz and 5 GHz
2 ax6 a/n/ac/ax 5 GHz and 6 GHz
3 Dedicated Sensor
(2.4 GHz or 6GHz)
Dedicated Sensor
(5 GHz)
  • Radio 1:
    • sensor
    • b/g
    • g/n
    • b/g/n
    • g/n/ax (Default)
    • client-bridge
    • ax6
  • Radio 2:
    • sensor
    • a/n/ac
    • a/n/ac/ax (Default)
    • client-bridge
When configuring sensor mode, set both Radio 1 and Radio 2 to sensor at the same time.
The World-Wide Universal Access Points 6 GHz radios support only the following Wi-Fi Alliance (WFA) 6E Compliant network authentication methods:
  • OWE (Opportunistic Wireless Encryption) for Open Networks
  • WPA3-Personal
  • WPA3-Enterprise
  • WPA3-Enterprise 192-bit mode
  • WPA3-Compatibility
    Important
    Important
    WPA3-Compatibility is not WFA compliant. WPA3-Compatibility supports both WPA2 Personal and WPA3 Personal on the same network. If a WPA3-Compatibility network is assigned to 6 GHz radio, only WPA3 Personal is assigned, thus making the network compliant.
ExtremeCloud IQ Controller requires that your 6 GHz radio network assignment be WFA 6E compliant. It rejects network configuration changes that result in 6 GHz radio network assignments that are not compliant. It might be necessary to redefine your networks when configuring the 6 GHz radio on the Universal Access Points.
For the AP3000/X, before changing the Radio 1 configuration from 2.4 GHz to 6 GHz, ensure that the AP is assigned a 6E WPA compliant network.
For all Extreme Networks access points, use the Extreme Networks certified ACC-WIFI-MICRO-USB console cable. Other MICRO-USB console cables have not been certified by Extreme Networks.
WPA3-Enterprise with 192-bit mode (AP3000)
WPA3-Enterprise with 192-bit security protocols offers better protection for sensitive data. ExtremeCloud IQ Controller treats 192-bit mode configuration like WPA3-Enterprise (802.1X/EAP), offering the same configuration options.
WPA3-Enterprise with 192-bit mode is supported on AP3000 and AP5010 only. Network assignment is restricted to profiles of supporting devices.
