The guidelines for reconciliation are as follows:
The following table lists the supported reconciliation cases and actions:
Reconciliation Case | Action |
Missing config on the switch | Push the EFA intended config to the switch |
Partial config on the switch | Merge the EFA intended config to the switch |
Conflicting config on the switch | Replace with EFA intended config |
The following sections show how various switch configurations are handled during reconciliation by Tenant Services.
