EFA does not provision reload-delay 90
configuration on
the Cluster Edge Port (CEP) Interfaces. EFA instead provisions
cluster-track
configuration on CEP when the CEP is configured as a
member of EPG (End Point Group) during EPG create and EPG update operations.
During upgrade from EFA 2.2.0 to 2.3.0, EFA marks all the CEPs with the
intended cluster-track
configuration and shows as configuration drift. On reconciliation of the drift, EFA pushes the
cluster-track
configuration to the CEP ports. Prior to the cluster-track
configuration
push, EFA
automatically removes the reload-delay
configuration from the CEP ports.
# efa tenant po create --name po11 --tenant tenant1 –speed 10Gbps --negotiation active --port 10.24.80.134[0/15] => CEP # efa tenant po create --name po12 –tenant tenant1 –speed 10Gbps --negotiation active –port 10.24.80.134[0/25],10.24.80.135[0/25] => CCEP # efa tenant epg create --name ten1epg1 --tenant tenant1 --switchport-mode trunk --ctag-range 1001 --port 10.24.80.134[0/35] --po po11,po12
#show run int eth 0/35 interface Ethernet 0/35 cluster-track switchport switchport mode trunk switchport trunk allowed vlan add 1001 switchport trunk tag native-vlan no shutdown !
Device1# show run int po 11 interface Port-channel 11 cluster-track switchport switchport mode trunk switchport trunk allowed vlan add 1001 switchport trunk tag native-vlan no shutdown !
Device2# interface po 12 interface Port-channel 12 switchport switchport mode trunk switchport trunk allowed vlan add 1001 switchport trunk tag native-vlan no shutdown !
