Device Image Management
Using maintenance mode, you can download firmware on one or more devices in the IP fabric with the minimal disruption to data path traffic. Both Clos and Non-Clos fabrics are supported. The maintenance mode feature is supported only on SLX devices running SLXOS 20.1.1 and later.
EFA supports the following firmware download features:
Supported Devices
The SLX-OS firmware download with maintenance mode is supported on the following SLX devices running SLX-OS 20.1.1 and later.
