As a load-balancing method, resilient hashing helps to lessen the possibility that a destination path will be remapped when a LAG (Link Aggregation Group) link fails.
When you create or update a tenant VRF, you can enable ECMP resilient hashing and you can configure the maximum number of resilient hashing paths allowed (8, 16, or 64 paths). Resilient hashing is disabled by default. The default number of allowed paths is the same as the default value for the SLX devices.
# efa tenant vrf create --name <vrf-name> --tenant <tenant-name> --rh-ecmp-enable=true/false --rh-max-path <8 | 16 | 64>
# efa tenant vrf update --name <vrf-name> --tenant <tenant-name> --operation <rh-max-path-add | rh-max-path-delete | rh-ecmp-update> --rh-ecmp-enable=true/false --rh-max-path <8 | 16 | 64>
The --max-path and --rh-max-path parameters can co-exist.
You cannot choose the specific devices on which to configure resilient hashing. Configuration applies to all SLX devices in the tenant VRF.
For more information about the commands, including usage examples, see the Extreme Fabric Automation Command Reference, 2.3.0 .
