You can bring an interface administratively up or down.
Tip
In SLX-OS, you can use the show interface ethernet command to see the status of the Ethernet interfaces on your device.
You can change the Admin Status for one or more IP addresses or for a specified fabric name. For more configuration examples, see the Extreme Fabric Automation Command Reference, 2.3.0 .
This example changes the Admin State on multiple IP addresses.
efa inventory device interface set-admin-state --ip 10.25.225.167,10.24.48.131,10.24.51.135 --if-name 0/20-22 --state up +---------------+-----+------+----------------+--------------+---------+--------+ | DeviceIP | ID | Name | Interface Type | Admin Status | Result | Reason | +---------------+-----+------+----------------+--------------+---------+--------+ | 10.24.48.131 | 110 | 0/21 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 142 | 0/20 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 148 | 0/22 | ethernet | up | Success | | +---------------+-----+------+----------------+--------------+---------+--------+ | 10.24.51.135 | 16 | 0/21 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 48 | 0/22 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 86 | 0/20 | ethernet | up | Success | | +---------------+-----+------+----------------+--------------+---------+--------+ | 10.25.225.167 | 9 | 0/21 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 89 | 0/20 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 1 | 0/22 | ethernet | up | Success | | +---------------+-----+------+----------------+--------------+---------+--------+ Interface Details --- Time Elapsed: 56.4964544s ---
This example changes the Admin Status for the specified fabric name.
efa inventory device interface set-admin-state --fabric nc_no_vni --if-name 0/20-22 --state up +--------------+-----+------+----------------+--------------+---------+--------+ | DeviceIP | ID | Name | Interface Type | Admin Status | Result | Reason | +--------------+-----+------+----------------+--------------+---------+--------+ | 10.24.51.135 | 48 | 0/22 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 16 | 0/21 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 86 | 0/20 | ethernet | up | Success | | +--------------+-----+------+----------------+--------------+---------+--------+ | 10.24.48.131 | 148 | 0/22 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 142 | 0/20 | ethernet | up | Success | | + +-----+------+----------------+--------------+---------+--------+ | | 110 | 0/21 | ethernet | up | Success | | +--------------+-----+------+----------------+--------------+---------+--------+ Interface Details --- Time Elapsed: 37.9236481s ---
