The following table describes information added to this guide for the Extreme Fabric Automation 2.3.0 software release.
| Feature | Description | Link |
| Admin status | The efa inventory device interface set-admin-state command now supports comma-separated lists of IP addresses and a Fabric name. | Change the Admin Status of an Interface |
| Port speed | The efa inventory device interface set-speed command now supports comma-separated lists of IP addresses and a Fabric name. | Configure Physical Port Speed |
| Maximum transmission units | The following commands now support comma-separated lists of IP addresses
and a Fabric name:
Configure MTU at the Interface or System Level |
| Breakout ports | The following commands now support comma-separated
lists of IP addresses and a Fabric name:
Configure Breakout Ports |
| Config-replay using startup-config | Backup restore using startup-config is supported. | Configure Backup and Replay |
| Tenant Service Enhancements |
| IP Multicast Fabric Provisioning | IP multicast fabric configuration on both 3 stage and 5 stage Clos fabric is supported. | IP Multicast Fabric Provisioning |
| Syslog notifications over RELP | New support for this release. | Notification Service |
| Backup and restore | Support for manual and scheduled backups, and for the purging of system and supportsave backups files. | EFA System Backup and Restoration |
| VRF resilient hashing | New support for this release. | VRF Resilient Hashing |
| In-flight transaction reconciliation | New support for this release. | Transaction Handling after Failover or Restart |
| Administered partial success | Tenant APIs configurations can proceed if at least one of the legs of the MCT is reachable and operational. | Administered Partial Success |
| Supportsave script enhancement | With this release, the supportsave script also captures the output of efa-show-running-config command. | Display EFA Running Configurations |
| Host name and IP address changes | New support for this release. | Change the Host Name or IP Address |
| Monitoring EFA Status | New support for this release. | Monitoring EFA Status |
For more information on this release, refer to the Extreme Fabric Automation Release Notes.
