Viewing Fabric Details
You can use several commands to view the details of topologies and configuration in your Fabric.
Table 1. Fabric show commands
Command Description
efa fabric topology show overlay Shows the overlay (VxLAN tunnels) connectivity of devices in a Fabric.
efa fabric topology show physical Shows the physical topology (LLDP neighbors) connectivity of devices in a Fabric.
efa fabric topology show underlay Shows the underlay (BGP neighbors) connectivity of devices in a Fabric.
efa fabric show Displays Fabric details.
efa fabric show-config Displays Fabric configuration details for the specified role (leaf, spine, super-spine, border leaf) or IP address.
efa fabric show summary Displays a summary of all Fabrics or of the specified Fabric.
The following is an example of output from the efa fabric topology show overlay command.
# efa fabric topology show overlay --name clos_fabric
| OVERLAY ECAP TYPE | TUNNEL TYPE | SOURCE LEAF IP | DESTINATION LEAF IP | SOURCE VTEP IP | DESTINATION VTEP IP | OVERLAY ADMIN STATE | OVERLAY OPER STATE |
| vxlan             | unicast     | 10.24.80.158   | 10.24.80.159        | 172.31.254.7   | 172.31.254.9        | up                  | up                 |
| vxlan             | unicast     | 10.24.80.159   | 10.24.80.158        | 172.31.254.9   | 172.31.254.7        | up                  | up                 |
| vxlan             | multicast   | 10.24.80.158   |                     | 172.31.254.7   | 239.1.1.1           | up                  | up                 |
| vxlan             | multicast   | 10.24.80.159   |                     | 172.31.254.9   | 239.1.1.1           | up                  | up                 |
The following is an example of output from the efa fabric show command.
# efa fabric show
Fabric Name: default, Fabric Description: Default Fabric, Fabric Stage: 3, Fabric Type: clos
| IP ADDRESS | POD | HOST NAME | ASN | ROLE | DEVICE STATE | APP STATE | CONFIG GEN REASON | PENDING CONFIGS | VTLB ID | LB ID |
Fabric Name: clos_fabric, Fabric Description: , Fabric Stage: 3, Fabric Type: clos
| 10.24.80.152 |     | NH9250-CI-Spine-01 | 64512 | spine | provisioned  | cfg in-sync | NA                | NA              | NA      | 1     |
| 10.24.80.158 |     | NH-158             | 65000 | leaf  | provisioned  | cfg in-sync | NA                | NA              | 2       | 1     |
| 10.24.80.159 |     | NH-159             | 65001 | leaf  | provisioned  | cfg in-sync | NA                | NA              | 2       | 1     |
CONFIG GEN REASON:
LD - Link Delete, LA - Link Add, IU - Interface Update, PLC - IPPrefixList Create, PLD - IPPrefixList Delete, PLU - IPPrefixList Update
MD - MCT Delete, OD - Overlay Gateway Delete, OU - Overlay Gateway Update, ED - Evpn Delete, PC - RouterPim Create, PD - RouterPim Delete
DD - Dependent Device Update, DA - Device Add, DR - Device ReAdd, ASN - Asn Update, PU - RouterPim Update, HN - HostName Update, NA - Not Applicable
PENDING CONFIGS:
MCT - MCT Cluster, O - Overlay Gateway, SYSP - System Properties, INTIP - Interface IP
C/D/U - Create/Delete/Update, PA/PD - Port Add/Port Delete
For App or Device Error/Failure reason, run "efa fabric error show" for details
For config refresh reason, run "efa fabric debug config-gen-reason" for details
