The ExtremeSwitching SLX 9250 Series switches offer a versatile and efficient core/aggregation switching functionality for both campus and data center environments. The SLX 9250 Series switches run the SLX-OS operating system.
The following table describes the ExtremeSwitching SLX 9250 Switch Models.
Each SLX 9250 Switch has a management port, a console port, a USB port, and SLX 9250 Advanced Feature License. A four-post mounting kit (part no. XN-4P-RKMT298) is provided with each switch. The following table lists the specific interfaces for each switch.
| Part number | Description | Introduced OS | Currently supported |
SLX9250-32C (SLX 9250-32C base) |
32 QSFP+/QSFP28 100GbE/ 40GbE ports, 128 x 25/10 GbE using break-out cables, 8 Core Processor, 16GB DDR4 ECC memory, 128GB SSD memory, 2 unpopulated power supply slots, 6 unpopulated fan slots. |
SLX-OS 20.1.1 |
Yes |
SLX9250-32C-AC-F (SLX 9250-32C with front-to-back airflow) |
32 QSFP+/QSFP28 100GbE/ 40GbE ports, 128 x 25/10 GbE using break-out cables, 8 Core Processor, 16GB DDR4 ECC memory, 128GB SSD memory, dual power supplies, 6 fan units, front-to-back airflow. |
SLX-OS 20.1.1 |
Yes |
SLX9250-32C-AC-R (SLX 9250-32C with back-to-front airflow) |
32 QSFP+/QSFP28 100GbE/ 40GbE ports, 128 x 25/10 GbE using break-out cables, 8 Core Processor, 16GB DDR4 ECC memory, 128GB SSD memory,, dual power supplies, 6 fan units, back-to-front airflow. |
SLX-OS 20.1.1 |
Yes |
| XN-ACPWR-750W-F
Modular 750W AC power supply, Front-to-Back airflow |
SLX-OS 20.1.1 |
Yes |
| XN-ACPWR-750W-R
Modular 750W AC power supply, Back-to-Front airflow |
SLX-OS 20.1.1 |
Yes |
XN-DCPWR-750W-F |
Modular 750W DC power supply, Front-to-Back airflow |
SLX-OS 20.1.1 |
Yes |
| XN-DCPWR-750W-R |
Modular 750W DC power supply, Back-to-Front airflow |
SLX-OS 20.1.1 |
Yes |
The following table list the supported SLX 9250 Switch Fan assemblies.
| XN-FAN-001-F |
Fan unit, Front-to-Back airflow |
SLX-OS 20.1.1 |
Yes |
| XN-FAN-001-R |
Fan unit, Back-to-Front airflow |
SLX-OS 20.1.1 |
Yes |
The following table list the SLX 9250 Switch supported Rack Mount Kit.
A four-post mounting kit (part no. XN-4P-RKMT298) is provided with each switch.| Part number | Description |
| XN-2P-RKMT299 |
Two-post NEBS kit for SLX9250 |
SLX9250-ADV-LIC-P |
SLX 9250 Advanced Feature License for BGP-EVPN and Integrated Application Hosting |
For information about licensing option for SLX-OS support for SLX 9250 Switches, reference the Extreme SLX-OS Software Licensing Guide
