Installing Internal Power Supplies
If your switch does not come with an installed internal power supply, you can install one or two power supplies.
The SLX 9150 and SLX 9250 Series switches supports 750 W power supply units using either AC or DC power.
Follow the instructions in the following sections to install the appropriate power supply and connect power to the switch.
