SFP/SFP+ Cable Distances and Types
This section shows one example of cable media types and maximum distances that support reliable transmission in accordance with international standards (except where noted). Refer to Extreme Networks Pluggable Transceivers Installation Guide for descriptions of optics and cables, as well as a complete list of supported cable lengths.
Refer to Extreme Hardware/Software Compatibility and Recommendation Matrices for a list of the cable types that are compatible with your equipment.
Table 1. SFP/SFP+ Cable Distances and Types
Standard
Media Type
MHz•km Rating
Maximum Distance (Meters)
1000BASE-LX
(1300nm optical window)
50/125 µm multimode fiber
400
550
500
550
62.5/125 µm multimode fiber
500
550
10/125 µm single-mode fiber
5,000
10,000
10/100/1000BASE-T SFP
(100 Mbps link)
Category 5 and higher UTP cable
150
(10 Mbps link)
250
1 Proprietary to Extreme Networks. Connections between two Extreme Networks 1000BASE-LX interfaces that use 10/125 µm single-mode fiber can use a maximum distance of 10,000 meters.
