Removing and Replacing Components
You can replace internal power supplies and fan modules, as needed, while the switch is operating ("hot swapping").
For each switch, ensure that all installed power supplies and fan modules have the same the airflow direction: either front-to-back or back-to-front.
Follow the procedures in this section to remove and replace power supplies and fan modules, and to remove a switch from a rack.
