Connecting the Ground Wire to a 750 W DC
Power Supply
Follow these steps to connect the ground wire to a 750 W DC power supply.
Warning
Connect the chassis ground wire before you connect any power
cables.
Warning
Disconnect the ground wire after you disconnect all power cables.
Verify that the DC circuit is de-energized.
Attach an ESD-preventive wrist strap to your bare wrist and connect metal end
to an appropriate ground point on the rack.
Connect the ground wire to the
grounding point on the power supply.
The grounding point is the
middle of the three slots. Directly beneath it, you will see the international
symbol for earth ground – – on the body of the switch.
Refer to diagram below -
Slots for Connecting Wires to the 750 W DC Power Supply for the
slot location.
Insert the stripped end of the ground wire all the way into the
slot.
Insert a #1 Phillips
screwdriver into the hole below the slot, and tighten.
Gently tug the ground wire to make sure it is fastened securely.
Connect the other end of the wire to a known reliable earth ground point at
your site.
When you have connected the ground
wire, connect the power supply to the power source using the two input cables. Follow
the instructions in "Connecting a 750 W DC Power Supply to the Source Voltage."
