Cable Distances and Types
Cable Distances and Types Cable Distances and Types below shows one example of cable media types and maximum distances that support reliable transmission in accordance with international standards (except where noted). Refer to Extreme Networks Pluggable Transceivers Installation Guide for descriptions of optics and cables, as well as a complete list of supported cable lengths.
Refer to the Extreme Hardware/Software Compatibility and Recommendation Matrices for a list of the cable types that are compatible with your equipment.
Table 1. Cable Distances and Types
Standard Media Type MHz•km Rating Maximum Distance (Meters)
1000BASE-SX
(850nm optical window)
50/125 µm multimode fiber 400 500
50/125 µm multimode fiber 500 550
62.5/125 µm multimode fiber 160 220
62.5/125 µm multimode fiber 200 275
1000BASE-LX
(1300nm optical window)
50/125 µm multimode fiber 400 550
62.5/125 µm multimode fiber 500 550
10/125 µm single-mode fiber – 5,000
10/125 µm single-mode fiber – 10,000
1000BASE-ZX
(1550nm optical window)
10/125 µm single-mode fiber – 80,000
100BASE-LX100
10/125 µm single-mode fiber – 100,000
1000BASE-BX10
(1490nm optical window)
(1310nm optical window)
1000BASE-LX70
10/125 µm single-mode fiber – 70,000
10/100/1000BASE-T SFP (1 Gbps link)
Category 5 and higher UTP cable
– 100
(100 Mbps link)
– 150
(10 Mbps link)
– 250
10GBASE-SR SFP+
62.5 mm multimode fiber 160 26
62.5 mm multimode fiber (OM1) 200 33
50 mm multimode fiber 400 66
50 mm multimode fiber (OM2) 500 82
50 mm multimode fiber (OM3) 2000 300
10GBASE-LR SFP+
10GBASE-ER SFP+
10/125 µm single-mode fiber – 40,000
40GBASE-SR4 QSFP+
50 mm multimode fiber (OM3) – 100
50 mm multimode fiber (OM4)
150
1000BASE-T Category 5 and higher UTP cable – 100
100BASE-TX Category 5 and higher UTP cable – 100
10BASE-T Category 3 and higher UTP cable – 100
The following tables below list the Extreme Networks 100Gb Direct-Attach Cables and the Extreme Networks 40Gb Direct-Attach Cables
Table 2. Extreme Networks 100Gb Direct-Attach Cables
Cable Type Part Number Length
QSFP28-QSFP28 Direct attach passive copper cable 10411 or AA1405029-E6 1 meter
10413 or AA1405031-E6 3 meters
10414 or AA1405032-E6 5 meters
QSFP28-4xSFP28 (4x25Gb) Direct attach passive copper breakout 10421 1 meter
10423 3 meters
10424 5 meters
QSFP28-4xSFP28 (4x25Gb) Active optical breakout cable 10444 20 meters
Table 3. Extreme Networks 40Gb Direct-Attach Cables
QSFP+ to QSFP+ Direct attach cable AA1404037-E6 0.5 meter
AA1404029-E6 1 meter
AA1404030-E6 2 meters
AA1404031-E6 3 meters
AA1404032-E6 5 meters
QSFP+ to QSFP+ Active optical cable AA1404028-E6 10 meters active optical
QSFP+ to 4xSFP+ Breakout cable AA1404033-E6 1 meter
AA1404035-E6 3 meters
AA1404036-E6 5 meters
AA1404041-E6 10 meters active optical
1 Proprietary to Extreme Networks. Connections between two Extreme Networks 1000BASE-LX interfaces that use 10/125 µm single-mode fiber can use a maximum distance of 10,000 meters.
