750 W Power Supplies Technical Specifications
Four 750 W power supply units are available for use with SLX 9150 Series and SLX 9250 Series switches:
Table 1. 750 W Power Supplies: Unpackaged Dimensions
750 W power supply – AC
front-to-back or back-to-front airflow
Height: 4.00 cm (1.57 in)
Width: 8.00 cm (3.15 in)
Depth: 20.60 cm (8.11 in)
750 W power supply – DC
Table 2. 750 W Power Supplies: Unpackaged Weight
0.81 kg (1.79 lb)
0.85 kg (1.86 lb)
Table 3. 750 W Power Supplies: Packaged Dimensions
Height: 44.5 cm (17.52 in)
Width: 27.5 cm (10.83 in)
Depth: 42.5 cm (16.73 in)
Table 4. 750 W Power Supplies: Packaged Weight
10.22 kg (22.53 lb)
10.50 kg (23.15 lb)
Table 5. Power Specifications (AC Power Supplies)
Voltage input range
85 to 264 V
Nominal input ratings
100-140/200-240V , 10/5.36A max., 50/60Hz
Nominal input current at full loads
10 A at 90 V (low-line)
3.7 A at 230 V (high-line)
Line frequency range
47 to 63 Hz
Maximum inrush current
35 A
Output
+12 V, 61.5 A
+12 Vsb, 3 A
Total output power not to exceed 750W
Power supply input socket
IEC 320 C14
Power cord input plug
IEC 320 C13
Power cord wall plug
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies
Power supply cord gauge
18 AWG (0.75 mm2) up to 6 feet or 2 meters
or
16 AWG (1.0 mm2) over 6 feet
Efficiency
Low Line: 88% at 50% load and 86% at 100% load
High Line: 90% at 50% and 100% loads
Table 6. Power Specifications (DC Power Supplies)
Nominal input
-48 to -60 VDC, 20.4 A
DC Voltage input range
-35 to -75 V
Inrush Current
21 A peak
Maximum wire size
14 AWG (1.5 mm2 copper stranded).
DC Output +12.2VDC, 61.5A; +12Vaux, 2.5A
Power (W)
750 W
Table 7. Environmental Specifications (All Power Supply Units)
Operating temperature
0°C to 55°C (normal operation)
Storage temperature
-40°C to 70°C
Operating humidity
20% to 90% relative humidity, non-condensing
Operational shock
30 m/s2 (3 G)
