To establish a serial connection to the console port on the device, complete the following steps.
| 1 = 40Gbps/100Gbps QSFP28/QSFP+ Ethernet ports | 2 = Console port: RJ45 |
| 3 = USB port | 4 = Management port: RJ45 |
The console or serial port is intended primarily for the initial setting of the IP address.|
Parameter |
Value |
Bits per second |
115200 |
Data bits |
8 |
Parity |
None |
Stop bits |
1 |
Flow control |
None |
Flow control is not supported on the serial consoles when attached to remote terminal servers and must be disabled to ensure proper operation.tip /dev/ttyb -115200
If ttyb is already in use, use ttya instead and enter the following string at the prompt:
tip /dev/ttya -115200
When the terminal emulator application stops reporting information, press Enter. You receive the following login prompt:
SLX login:
