If you enable STP on MCT nodes, each node acts as an independent (not interconnected) STP switch. This situation results in STP state flap at the node connected to the CCEP port, because it receives two different Bridge Protocol Data Units (BPDU) on that CCEP portKey = MCT_LACP_KEY_BASE (3000) + client_ID Port ID (16-bit unique value) = 5-bit (slot value) + 8-bit (port value + 3-bit) (MCT position offset)
