To configure and initialize ERP using APS and IEEE 802.1ag (Dot1ag), you must set up one RPL owner and one or more non-RPL nodes. Other nonparticipating switches can exist in the ring.
You must perform the following minimum configuration tasks for the RPL owner:
You must perform the following minimum configuration tasks for each non-RPL node:
The following example configures IEEE 802.1ag compliance.
device(config)# erp 1 device(config-erp-1)# dot1ag-compliance device(config-dot1ag-compliance)# left-interface domain-name md1 ma-name ma1 mep 2 remote-mep 4 device(config-dot1ag-compliance)# right-interface domain-name md1 ma-name ma3 mep 2 remote-mep 4 device(config-dot1ag-compliance)# enable
Use the no dot1ag-compliance command to disable the feature.
The domain-name parameter specifies the MD name for 802.1ag CFM.
The ma-name parameter specifies the maintenance association name. This can be up to 21 characters long.
Refering to the example topology above, corresponding configurations for this feature on Node 1 and Node 2 are as follows.
Node 1 Dot1ag configuration
protocol cfm domain-name md1 id 1 level 7 ma-name ma2 id 2 vlan 222 priority 7 ccm-interval 3.3-ms mep 2 down ethernet 0/1 ! ! ma-name ma3 id 3 vlan 222 priority 7 ccm-interval 3.3-ms mep 1 down ethernet 0/2 ! erp 222 left-interface vlan 222 ethernet 0/1 right-interface vlan 222 ethernet 0/2 dot1ag-compliance left-interface domain-name md1 ma-name ma2 mep 2 remote-mep 1 right-interface domain-name md1 ma-name ma3 mep 1 remote-mep 2 enable end
Node 2 Dot1ag configuration
protocol cfm domain-name md1 id 1 level 7 ma-name ma2 id 2 vlan 222 priority 7 ccm-interval 3.3-ms mep 1 down ethernet 0/1 ! ! ma-name ma1 id 1 vlan 222 priority 7 ccm-interval 3.3-ms mep 2 down ethernet 0/2 ! erp 222 left-interface vlan 222 ethernet 0/1 right-interface vlan 222 ethernet 0/2 dot1ag-compliance left-interface domain-name md1 ma-name ma2 mep 1 remote-mep 2 right-interface domain-name md1 ma-name ma1 mep 2 remote-mep 1 ! rpl-owner rpl vlan 222 ethernet 0/2 enable end
