Connect to the Management Console
The console port on the top of the switch is used to establish a serial connection between the switch and a terminal emulator or a computer with terminal emulation software so that the switch can be managed locally.
Console Port for the 8-port and 12-port Switches
Console Port for the ISW 8GbP, 4-SFP+ Switch
Console Port for the ISW 24GbP, 4-SFP Switch
To establish a serial connection to the console port on the device, complete the following steps.
  1. Verify that the device is powered on by verifying that all power LED indicators on the management and interface ports, power supply and fan modules display a steady green light.
  2. Connect the RJ-45 serial cable provided with the device to the management Ethernet port of the device. Attach the supplied RJ45 (male) connector-to-RS232 DB9 (female) connector to the RJ-45 serial cable, then connect it to the PC COM port.
    Important
    Important
    Using a different cable than the one provided with the switch can cause bootup issues.
  3. Access the device using a terminal emulator application (such as HyperTerminal in a Windows environment or Tip in a LINUX environment).
    Disable any serial communication programs running on the workstation (such as synchronization programs).
  4. Open a terminal emulator application (such as HyperTerminal on a PC, or TERM, Tip, or Kermit in a LINUX environment), and configure the application as follows:
    • In a Windows environment:
      • Baud rate: 11520
      • Data bits: 8
      • Stop Bit: 1
      • Parity: None
      • Flow control: None
      Flow control is not supported on the serial consoles when attached to remote terminal servers and must be disabled to ensure proper operation.
    • In a LINUX environment, enter the following string at the prompt:
      tip /dev/ttyb -115200
      If ttyb is already in use, use ttya instead and enter the following string at the prompt:
      tip /dev/ttya -115200
      When the terminal emulator application stops reporting information, press Enter. You receive the following login prompt:
      login:
    • Follow the steps to log into the switch and initial configuration steps in Configure the Switch for Use.
